Symbian S60 - Protect Your Data With Remote Phone Lock
Reset Default lock code:
  1. Go to Menu → Settings → Phone → Phone mgmt. → Security → Phone and SIM card.
  2. Click on “Lock Code”. you will be asked to give existing lock code. This code depends on the mobile phone model and the right code will be specified in the phone’s user manual. for example, for 5800XM, the phone lock code will be 12345 by default.
Remote Phone Lock:
From the same menu, select “Remote Phone Locking”.
You will be asked to enter new “Remote Locking Message”. This will be the message that you have to send in SMS when you want to lock the phone.
eg: lock from thief
Reenter the same message for verification.
If both the messages are identical, you will be asked to enter the lock code.
Use the phone’s lock code and if everything is enetered properly, you will get the message “Code Accepted”.
How to Lock:
In case you lost your phone and you want to lock your phone, SIM and memory card, you just send an SMS to your phone with the subject being the “Remote locking message” like “lock from thief”.
Once the SMS reaches the phone, SIM/phone/memory card will be locked and the phone user need to enter the right lock code to unlock the phone.
If the theif removes your SIM then what? how will the message arrive on your device?
^ yeah rite wat if the clever thief throws the SIM ?
But thanks for sharing mate, i didn know bout it
repped :grinning_face_with_smiling_eyes:
simple. Track the phone number based on IMEI (file a case, go to operator, find new phone number) and send the sms to new number :slight_smile:
I think police department will not take care until there is a national security is involved with your phone’s theft.
^nah. all you need to do is file an FIR and take it to carrier. And they can do the necessary to make the phone unusable :slight_smile:
Can this feature be obtained on old N70 through a firmware update?
