Which T.V tuner card is best…i need a good t.v tuner card 4 my p.c…which have
a nice software… , my budget is Rs:1500… which one is gud Internal or External..? …which company is nice..and i’m gonna use it with Dish T.V..so i need a Audio Video input…which means i hav 2 connect A.V cable in to it ..pls help
thanx in advanc
look out what are you saying ??
why to go for internal tv tunner card:::
1)cost is less
2)good bundle of media software
3)u can record the show
4)if ur card of windows media center- u can use all those media center facilities(any media center internal card will cost u 2-2.5 k INR..but its worth–PixelView is there)
Why go for External Card:
1)No need to use the PC/CPU when watching TV
2)No risk of damaging your motherboard by malfunctioning of your internal TV tunner card
3)portable-u can carry easily (if USB)
4)u will get a descent external tv tunner(from techom/frontech) at 1800 INR(for lcd)/1000 INR(for CRT),better quality will cost u more
5)I am not sure about the recording n other features of external tv tunner box
Pinnacle PCTV Stereo is best option for internal card at 1.8 to 2.2k maximum.Look this card has very low CPU usage and great recording capability and picture quality.Never buy Combo boxes(direct to monitor) all is crap with poor picture quality . If you can spend near about 3k then go for PCTV 50e,Below one is USB PCTV 50e and have fully drivers support for windows vista
If u do not want to record anything, than go for External TV Tuner Box.
And u do not have to remove and reconnect the display Connector everytime u want to switch. It’s as simple as switching off the Tuner Box by remote to go to PC mode & On it for TV mode…
I like the ASUS one its really awesome, But the price will be around INR 5k+..
And also no launch date is available. I’ll buy one if the price is decent :ashamed:
