MetkuMods - Because you love your hardware!
apparently, the 1070 mAh BL 6C can be used instead of a 850mAh BL 5C. had to remove the grey sticker around it , and shave some plastic off one edge as mentioned in the guide to make a perfect fit, but otherwise fine.
My 2310 is already wearing a 1110 skin- the shopkeeper was wondering how i got a colour display on it . the battery cost 300, but i took off the sticker , and fit it right in front of the dealer. he was like
and gave me a 50 rs instant discount saying that it was because I wouldnt be claiming warranty. He asked me if i did this to all my phones
am charging it now. will post this coming weekend how long the battery lasted, but will be using only the handsfree just in case it decides to explode
