Tony Hawks American Wasteland problems
ive run into a problem with tony hawks american wasteland. im using the backed up version.
whenever i try to save the game i get this message :
i ran a search on google for similar stuff but got absolutely nothing. the game runs fine but its no use when the game cant be saved in the story mode or anywhere else and i have tons of freespace and virtual memory too. i uninstalled the game and installed it using the “typical install” but to no avail.
very grateful for any help
Just a guess… Is there any permission issues on the Save Games folder ??
well thats another story .. :confused:
i dont know where the game saves. theres no savegame folder in the directory and nothing in my documents either…
make a new profile and then try saving…
P.S. Whats with those crappy gfx :expressionless:
thats the games menu
there isnt any profile system in tony hawks..
Check the Windows error logger if u see any thing there.
Or u will have to search on ur comp. Or see in the Readme file for info.
nothing in the error log and nothing in the readme file… … . . . ., .,.., ., . , ,
