[HEADING=2]TP-Link Archer TX20UH AX1800 High Gain Wireless Wifi 6 USB Adapter[/HEADING]
**Product Link: **[Archer TX20UH](’
https://www.tp-link.com/in/home-networking/high-gain-adapter/archer-tx20uh/’
Fast WiFi 6 - Break the gigabit barrier with speeds up to 1201 Mbps (5 GHz) + 574 Mbps (2.4 GHz).
Dual Band Wireless - 2.4 GHz and 5 GHz bands for flexible connectivity.
Broader Coverage - Connect to your WiFi from wherever in your home with high-gain antennas and Beamforming.
**Lower Latency Gameplay - **OFDMA and MU-MIMO ensure the most efficient WiFi connection for your PC.
**Improved Security - **WPA3 provides the latest security enhancements for personal password protection.
**SuperSpeed USB 3.0 - **Up to 10x faster transfer speeds than USB 2.0
Personal Experience: Excellent performance, can match wired Ethernet speeds for normal usage provided you have good wifi6 router.
Condition is excellent, hardly used for less than 100 hours. I had bought for my mini-PC, however due to change in work, no longer able to use it so selling it.
Please note
- This is the high powered expensive version, not the cheaper std ver tx20u (minus the H)
- Outer packaging box is little damaged (check pic) as have small kids at home
