Compact 2.5G Cloud Gateway with 30+ UniFi device / 300+ client support, 2.3 Gbps IPS routing, and expandable NVR storage for Protect CCTV cameras.
Supports upto 4 different ISPs at the same time for load balancing or failover.
Condition: New. Used once for testing whether it was DOA or not. It works 100% and flawlessly as expected.
Link to tech specs on Ubiquiti website:
It was imported by Anmol Bharadwaj few months back so assume no warranty for US based products.
This does not have inbuilt Wifi. But it can work with ANY independent Wifi Mesh system or you can even buy Ubiquiti access points from their Indian website or import from their US website using any forwarding service.
Upgraded to 10G Fiber Gateway.
Hi @@d5aqoep - This unit is xxx-NS not xxx-NX (as seen in your pics) and the link you provided mentions only 1 LAN is remappable to WAN so total 2 WANs capable, not 4, right?
Does anyone have any pointers to where I can get a full in-depth overview/walkthrough of the UI and settings/features this unit has?
I want to try ubnt ecosystem eventually - wanted to check any of these devices can handle at least 3 WANs - with features that can at least match my current TP-Link ER605 like policy-based-routing, in-built wireguard client/server, etc…
hmmm the “technical” section says “max 4 WAN” but not the overview lol…
@@vishalrao It is NS as it’s also visible in the last screenshot. I am unable to edit the title. Sorry.
Yes. This unit can handle upto 4 WANs with 5th port for feeding to a switch or PC. Make sure you are on latest 9.1 Network Application. I can fully help you in setting it up. Policy based routing and wireguard VPN is supported. This is the perfect 2.5G device to enter into Ubiquiti Ecosystem.
This device is capable of PPPoE hardware acceleration and as a result, I got following speed:
LTT Short Circuit review.
@@d5aqoep thanks for clarifying - I’m still on the fence ATM - GLWS!
Price drop to Rs. 24,000
Want to do a quick sale.
Final Price drop Rs. 23,000
It’s now sold to a member here.
