This is unofficial quick guide about how to run the exeem file sharing program on Linux operating system, since its only for windows.
Now that you have wine installed and configured, here are the easy steps how to do it:
- Exeem installation with wine:
Option 1 - Copy your existing exeem directory from your winbox to your wine ‘Program Files’ directory in your virtual c:/ drive, or whereever.
Option 2 - Download exeem installation file and execute it ‘wine exeem-setup.exe’ and install it.
- Exeem under wine configuration:
Open your wine config file (~/.wine/config usually) and put this at the end:
"*" = "builtin, native"
"dciman32" = "native"
"dciman" = "native"
"shdocvw" = "native"
"msvcp71" = "native"
"msvcr71" = "native"
"gdiplus" = "native"
If you dont have those dll files, then you can get them here (www.google.com) !
- Go to exeem directory and type ‘wine eXeem.exe’ and thats it! It will ask you for serial most probably since your exeem registry data is clear..
Final notices:
[quote]
If it hangs up then minimize the window and maximize it back, then it will be back to normal.
- If you change your configuration, including adding the serial, the changes will be saved when you exit the exeem successfully.. - You might get an annoying runtime error on exit. - Ive tested it with eXeems 0.16,0.17,0.18 betas and [exlite](http://exlite.net/). - If you use the beta version <0.20, then you can close the serial request window. - All the options are working fine.
[/quote]
**ScreenShots : ** eXeem works under Linux :
Screenshots are not fake and were taken with the screen capture tool in fluxbox.
Guide found via eXeem
