The pioneer 109D is a gr8 drive, but chk out the Benq 1640 too but you won’t get dvd-r DL support with it if that’s such a big deal. The Pioneer 109 also cannot set book type on dvd+r/rw media if thats important to you. The write quality is obviously amongst the best for the Benq 1640.
hmm benq is better as you get local warranty.. which you might not get with the pioneer.. lest anything goes worng with the drive..
one of my friends has a pioneer 109D.. great drive hasnt given him any probs.. the drive was able to write dvd`s which the lg drive failed to recognize… which was great!!
Usually old stand alone players cant read dvd+r/rw for which u can change the book type to other formats to ensure compatibility. But looks like you wont be needing it. On the mouse i seriously cant comment, both are very good mice and both have the ability to adjust resolution on the fly i think.
BenQ 1640 n LG 4163B are amongst the best as of now .. Do take a look at the Plextors..
about the mouse, both have the same sensor.. the deciding factor shud be the size.. u’ve seen the MX518 in action.. check out how big (or small, comparitively) the Razer is..
Oh ! Missed the thread completely. Like everyone concluded Benq 1640 it is ! And yeah masky is right both the mice use the same sensor, i think eddy or some1 had posted a similar thread on it…
Regarding the mouse I would prefer the Logitech MX 310, its lighter and fits perfectly and is cheaper and unless you are gaming at 1600*1200 the higher sensitivity is not gonna make a diff…
