Hello All,
I got an power adapter with the following specs
Input - 110 V-240 V ~ 50/60 Hz 0.8A
Output - 12V 1.5A
It has US plug system.
If I get it connected to Indian plug with International socket or via a plug adapter, will it work?
Let me know please.
Jee
December 25, 2024, 1:44pm
3
As long as it takes 230/240 volts then it should be fine I suppose, can’t remember what the ac frequency is but 60 sounds right. Electrical/electronic majors can pitch in here for more details. My gaming rig psu is also an American plug, never had any issues with it using a 100₹ adapter.
Hello All,
Output - 12V 1.5A
Let me know please.
It will be fine.
India has 230V at 50Hz which falls within the specifications of the plug.
For the most part, modern consumer electrical appliances work across different domestic electricity standards.
I too have had multiple devices from the US which worked/charged fine in Indian socket.
Thanks for all your inputs.
Will try it out today.
It says 110-240v & 50/60hz so it means it can be used everywhere.
It worked without any troubles.
Rahyro
December 27, 2024, 11:05am
8
Great. Just to let you know that it will work in all countries.
