USB device recognition problem
I had recently reinstalled the OS ( Win XP Pro ) on my system. When I connect a USB drive to the system, it recognizes something is connected but shows up as Unknown device. The same happened when I tried to connect my Nokia usb datacable.
Sequence of installation:
  1. Installed the OS
  2. Installed SP2 & patches
  3. Installed chipset driver
  4. Installed USB2.0 driver that came alongwith my motherboard CD.
When I first got my system, the sequence of installation was like:
  1. Installed the OS
  2. Installed chipset driver
  3. Installed USB2.0 driver
  4. Installed SP2 & patches
[ Running a Asus k8n motherboard ]
Back then, it could detect my friends iPod correctly. Am I doing something wrong with the installation? What could be the problem?
Thanks,
Vignesh.
Solved this problem, found out that I had goofed up with the front usb port connections :ashamed:
