Vertical GPU mount for Lian Li o11d EVO case
Hi I am looking to get vertical GPU mount compatible with Lian Li O11 Dynamic EVO Black case since their official mount seems to be out of stock online
I contacted Lian Li but they redirected to ali express which doesnt ship to India.
Is there any compatible alternative I can get?
Google search gave the following results:
This comes with a riser, but I am not sure if it has the bracket as well
This looks like the bracket
  1. Pcie3, rtx 4090 needs pcie4
  2. & 3) they’re for mounting gpu upright beside mobo. Not what I am looking for
Got your point, but my question is, you need the first one, correct? , but with pcie 4.0, do case manufacturers update this stuff, like once its launched with 3.0, do they actually update the riser cables to 4.0 or 5.0, when newer pcie versions roll out? Because if not ig u’ll have to use a 3.0 riser/buy the bracket and change the riser manually..
