Barebones kit, you’d need to add switches and keycaps
gone
oos…
A fully built keyboard is there on stackskb for 6k :-
Aula F75 available for 4.6k on amazon after card discount.
I’ve had lot of trouble with its firmware. Keys stop working randomly. I would stay away from Aula till they sort their firmware. Other than that its a great KB.
Aula F75 is the most recommended model on/r/mkindia for quite some time now so if such issue was there then it would have been come to light already. You most likely got a bad piece (ppl there say more chances of it happening if ordering via amazon).
The hardware is great, its the firmware that is the issue. Maybe there is something on my PC which is creating conflicts, but its frustrating enough for me to stop using it for now.
How do you know it’s firmware? I mean does the issue happen even on wired connection. Have you tried it with some other pc/laptop? Have you tried warranty support to get it replaced?
vortex clears
Walking Dead reference?
As it happens randomly. Like if I change the connection to wireless, it’ll start working well till its discharged. After next recharge it starts giving trouble again.
And even keys are random, sometimes one key doesn’t work, sometimes another one, sometimes 3-4 keys don’t work. And there are weeks when everything works well. If I uninstall and reinstall the software, it works for some time, then starts causing problems. Don’t think a hardware issue explains this.
Nope, only ever played the games
Why not avail replacement under warranty then?
If its a firmware issue how does getting it replaced help? Anyway I had ordered from epomaker, which takes long for shipping, plus the risk of it getting stuck somewhere. So I decided to wait for firmware update to resolve.
That’s because I have not seen any such firmware issues on /r/mkindia where almost every day there are at least a dozen comments which mention Aula F75.
