Which smart LED strips to choose?
The better question is: Which ecosystem is better? Philips Wiz, Govee, TP link Tapo, Kasa…
What I’m looking for primarily:
  • Tunable white. I’m not that much into RGBTQ.
  • Bright! I like to use them as primary light source.
  • Shouldn’t be expensive, like Philips Hue
  • Good to have options apart from LED strips like recessed lights. That way, I can control all of them through a single app.
  • Good integration with Google Assistant
  • First class availability in India is good but not necessary.
Limited-time deal: HomeMate Wi-Fi Multicolour Smart LED Strip Kit | 10 Meters | Music Sync Feature | No Hub Required | Works with Amazon Alexa, Google Home & Siri (RGB 10 Meter Kit with Built-in Mic Controller)
https://amzn.in/d/aGIirVs
@ ₹2.2k
TP-Link Tapo Smart LED Light Strip, two lights included (2x 5 meters each), Wi-Fi App Control RGB Multicolour LED Strip, Works with Alexa &Google Home,Suitable for TV Kitchen DIY Decoration(Tapo L900-10)
https://amzn.in/d/eUepw5K
@ ₹3k
How is the HomeMate?
Use ws2812b/Sk6812 led lights with EPS 32 controller module with WLED to control it
These are installed in my wifes sister’s house where false ceiling and cup boards have got recently upgraded and almost every corner of the ceiling and cup boards inside were installed and were made to start in such a way that if a person comes into the room or opens the cupboards they turn on. I am also thinking to get them installed in our house.
If you’re torn between Philips Wiz, Govee, TP-Link Tapo or Kasa for tunable white performance, brightness, price and Google Assistant integration, check out this detailed comparison:
Each ecosystem has its strengths:
  • Philips Wiz: Best brightness, CRI, HomeKit support; premium price.
  • Govee: Highly customizable scenes, competitive pricing; slightly lower CRI.
  • TP-Link Tapo / Kasa: Budget-friendly, reliable performance; fewer advanced features.
For a balanced blend of quality, features, and cost, Govee is our top pick. If you prioritize maximum brightness and color accuracy—and HomeKit—Philips Wiz is unmatched. Budget shoppers will find excellent value with Tapo or Kasa.
