Why do my 3w LED bulbs glow faintly when powered off?
Hello!
I have a light fixture with two bulb holders and wired for two-way switching.
Earlier it housed 7w LED bulbs which didn’t have the issue I’m facing after I fitted it today with 3w Halonix-branded (actually 2.9w as printed on the box) LED bulbs.
This evening I noticed they both faintly glow when they’re switched off. I don’t see this with couple of same bulbs fitted in another light fixture in the same house.
What could be the issue?
Is it potential wiring issue with the two-way switches like a short-circuit or current leakage or something like that?
In any case I’ll be informing and getting an electrician to check this out.
Thanks!
I have similar 3w led bulbs which when switched off glow extremely dim and can only be noticed in pitch dark darkness. I inquired with an electrician and he said due to earthing carrying a certain amount of tiny power some bulbs are extremely sensitive to current and can even glow to the tiniest current it senses.
I wasn’t actually bothered but just curious on such a behavior.
In fact during Diwali I observed in a few balconies of other flats that their string lights would still glow dim even though the entire flat was in darkness.
Let me know what the electrician says. In my case, I do not have any 2-way switch but if I install those bulbs in any rooms the effect is the same. But it does not keep glowing the entire night but for some time like on-off itself. Bhutiya behaviour! But string lights glow 24x7.
You can also try this: Take an led and simply insert it in heavy points like geyser, AC, fridge without switching on the button (else be ready for a big bang theory) and you will see it glows to 20-30% of its lumens value. Its all about earthing.
Two possibilities
More likely, your switch is wired to neutral and not live.. In which case low current devices can obtain enough potential difference between the active 220V supply and the small length of wiring to the open switch on the neutral line
The other being that the switch is wired correctly but your neutral is not at zero.
Both possibilities can be easily checked with a DMM
Thanks I don’t have a dmm. Getting my electrician to check it.
My guess, electricity from other wires from the same conduit causing interference through induction.
Check with multimeter. See if there’s any voltage.
In my case, the 3w down light dimly flashes once every few minutes at night after i switch it off. And its very faint. Can only make it out with blackout curtains drawn and room totally dark.
Ha ha .. Electroboom ..the professional dumbass .. made my morning. Love his videos.
This is due to the switch being on neutral and the live passing through the bulb.
I have same condition with one of my bulb and it’s visible bright at night.
Might as well get one.
The basic chinese ones cost less than a medium sized pizza at any local electrical store :slight_smile:
And they are usually more than adequate for basic usage
I was replacing a electrical board in my house and while shoving wires inside the new board, the ground wire and the phase wire for a 1w led bulb touched and the led bulb got lit (the breaker was off).
I measured the voltage between ground and neutral, it was 14v, which was enough to light up the bulb. No idea why the difference is so large, it should be only few volts.
Be careful if you will be sticking in a cheap multimeter into the mains socket. That’s usually not recommended.
why?
Even my Eveready 20w LED Bulbs glow in the dark after they are switched off. I bought 10pieces in amazon sale for 440rs. All are working since 1.5 years.
this happens because a person starts working under some electrician and then himself becomes electrician with lower knowledge then the person for who he worked before. this cycle goes on. An educated electrician knows about 95% things his assistant 90% and so on. That’s why they have not proper knowledge and work in rush connecting neutral to switch and causing other problems
May be a plan by power supplying company to let user use more electricity even when switch off gadgets, appliances/lights yo increase power bill :face_with_tongue: :smiling_face_with_sunglasses: :wink:
Cheap quality multimetres could result in an electric shock or arc flash. Since they are not calibrated, faulty diagnostics could lead to potentially dangerous situations.
I had to open up sockets and wire them correctly everywhere in the house. Left pin hole on socket is neutral and right pin hole is phase.
3 place I have seen the main MCBs connected to neutral and not phase and I’m not an electrician. Correcting it trips the main dual pole MCB. Cctv equipments need correct polarity from my guessing.
I use a fluke and also have a bevy of cheap multimeters around the house.
With the fluke, I am comfortable using my own fingers as the ground with the sensor wire plugged in mains.
With the cheap ones, I prefer using any nearby metal object as ground.
These cheap DMMs are typically rated up to 600V. While I wont use them anywhere near 600, 220V is absolutely fine with them.
