Wifi solution for pc
Please recommend me a pci card which has swapable m.2 wifi card,my mobo doesn’t have m.2 a/e slot for wifi
I had decided to buy fenvi ax1800 from Amazon but that particular model have soldered wifi chip
I can wait for a month or more it the product is available to import from china, there’s a asus ax3000 something available in market but it costs 4500rs
Regarding the hot swapability, if the pci card is having a thick heatsink kind of thing then can i assume it to be hot swapable ?
There are some listing on ebay selling pci card with mt7921 for 18$, I’ll swap the wifi card with ax210 if i feel the need
Attaching some photos of cards which i think should be hot swapable
Why do you need a hot swappable pci wifi card?
How much speed are you expecting from your wifi?
Have you considered using this standalone solution > [HERE](’
Amazon.in
PS- the image linked above is just a blur
It allows for future upgrades and also a possibility of using it in a laptop in future
Fixed the image
[Get this](’
Wireless Wifi Network Card Mini PCI-E To PCI-E 1X Desktop Adapter + 2 Antennas | eBay
). It has free shipping too, very cheap solution. You’ll need to get a wifi card separately.
You can use PCIE X1 to M.2/NGFF (A+E Key) WiFi Bluetooth Wireless Module Adapter Card
That is exactly what has been suggested just above dude.
