Hi all,
I had bought a DSL-2750u about a year back. The modem has been good from the start and is giving me good service, though not know whether this could be bettered or not hence sharing the stats as can be looked via going to 192.168.1.1 > Status Statistics :-
bug going down on the same page, I see things like these :-
As can be seen there are a few CRC checksum Errors but only in one column (Upstream) . Dunno what the other acronyms are for. For the attenuation bit, can I do something or just have to wait/call the friendly BSNL engineer and see if he can do something ?
Update: For some reason the first image is not coming hence shared it as a hyperlink, sorry.
These statistics suggest that you have a very noisy line, line stability is not that good. Inform your ISP of the same and get the issue rectified. Also, if possible get the connection at the junctions boxes installed properly/neatly.
I’d say his attenuation is in line with the distance he said. approx 14 db/km
Why is 18.5 dB and 9.5 dB very high ?
for reference Attenuation
20dB and below is outstanding
20dB-30dB is excellent
30dB-40dB is very good
40dB-50dB is good
50dB-60dB is poor and may experience connectivity issues
60dB or above is bad and will experience connectivity issues
