Looking to buy a budget friendly and good Wireless headphone with Mic and Bluetooth dongle as My PC doesn’t has Bluetooth connectivity.
Headphone will be used for regular work on PC. (to dictate notes & work along with Google Voice Typing)
On mobile for conference (hardly once a month, so both speakers + mic.
Should have volume control
Should be able to connect/disconnect calls without touching mobile My budget max goes upto 3000 (prefer under 3K)
Here are some options I found online (but those are without Bluetooth dongle, seller claims Bluetooth dongle can be attached to PC to get this working, can someone guide which dongle shall work with same ?
You should get a USB extension cable if you are using any dongle as that will allow you to place it in front and give the best range and signal quality.
Nobody sells bluetooth dongles with headphones. You can buy any branded dongle online and that should work. There’s one tp link dongle in trade section for 300.
I doubt there are any good non-BT wireless headphones with mic, heck no great BT options as well, just ok ones. I was looking to move to wireless from HyperX Stinger, but decided it is best to live with wire.
Also, I sometimes get issues with my OP Bullet Z on windows 10, like when I use its mic, earphones become mono instead of stereo, my PC has BT 5.2. This was another reason I dropped BT headphone idea.
Boom mic means clear voice, works for dictation and others hearing you. It’s detachable too. Since its close to your mouth less need for noise cancelling
Missing a mute button though which would have made it killer
Above person’s review of the Tribit for office calls
But realise that USB3 is better to avoid interference than USB 2. If you can use the front ports then you could get away with a shorter extension cable or not need one at all.
