Zebby Antibiotic Cable Management
here it is i was becoming bit jealous after watching some cable management pics on TE :face_with_tongue: And was bored because of engg. studies :ashamed: :confused: So decided to do something good for the day :slight_smile:
What i decided was cable management is antibiotic (i know sounds weird :face_with_tongue: ) but still true…actually my cabby is small compared to the huge TX 650 thats sitting in it :face_with_tongue: so from now on let pics do talking :slight_smile:
NOW :
**THEN : **
Final with side panel :slight_smile:
good but it can be better, in my antibiotic only 2-3 cables are visible from side , i will show pics after i get new mobo and arrange cables .
nice cable management out there even I hv used the same technique for cm on my antibiotic
here’s mine requires some more finishing:ashamed: :ashamed:
thanks..guys :slight_smile:
@roboghost but i have 4hdd while ur is only 2 :frowning:
and i guess 9800 is also smaller than 4870 :confused: 4870 cramps all :face_with_tongue:
i have 3 x 500gb , but all in DVD drive bays :face_with_tongue:
^^ oh hehe thats good place :face_with_tongue: :slight_smile:
NIce yaar .. i have the same cabby .. will have to learn a lot from u :slight_smile:
Poor layout, I need camera to post Elite 330 PICs.
^^ what more can u expect from a zebronics cabby ?? its not stacker that u go on saying it poor :expressionless: and elite is much better than antibiotic..come at my place and take a look how full the cabby is and let me get a new cabby in couple of months and then i will post again lets c huz is poor at that time :-/
I havnt said - “elite is much better than antibiotic
BTW cut this thing -
Its not allowing U to tie cables w/ 5.25" bay spare holes. Edit : Oh its permanently fixed w/ mobo tray.
yea its fixed :frowning: otherwise i would have got it bent somehow :frowning:
Really nice !. Guess I can learn a lot cos i use the same cabbie ! :blush:
even mine is a same cabby … got nice space.. now need 2 add some fans ..
infact yours can be even nice coz you are having modular power supply :slight_smile:
Nicely done w1nd but your HDDs may run a tad warm.:slight_smile:
And you know you need a case upgrade- soon. :face_with_tongue:
Your rig needs atleast 65-75cfm 120mm fans at the front and the back asap.
With that setup, a 2140 at 3G and a 8800GT SSC, the psu fan (meant to cool psu innards) is primarily acting as the exhaust fan and your poor psu runs hotter and is deterioriating day by day.
Do your psu/rig a favour and get two 120mm fans for intake and exhaust.
Amigo LED fans (65-70 odd approx), are similar to Glacialtech (80-85 cfm approx) ones, are a bit buzzy but do the job ok; 200/- shipped each, via Amarbir iirc.
Plus you get a few more LEDs lighting up the case (since u got an antibiotic and mostly like LEDs). :face_with_tongue:
Nice work w1ind.
thanks Rockfella :slight_smile: glad you liked it :wink: esp a person with CM 690 liking it is very nice feeling :slight_smile:
thank you Bikey sir :)… u liking something…then that something must be really nice :face_with_tongue: … hehe and yes my hdd runs warm :frowning: remember i had IMed you sometime time back as i was in dilemma of cabinet :ashamed: now its gone and mostly upgrading fully after my results :slight_smile:
Nice work, would love to start working on the same thing for my cabinet. Will PM you for your help if you dont mind.
thanks :slight_smile:
sure buddy you can pm me anytime :slight_smile: always ready to help TE ppl :slight_smile:
What’s up with that critique? :no_entry:
@w1nD
Nicely done!
