Car & Bike 10k audio system for zen...
devilishevil
i ve got an old zen which is my dads old car. I ve made changes externally to make it look much better and also tweaked the engine somewhat, Now I need a good music system,including player, speakers and sub woofers.. but my budget is restricted to 10k... What should I get?:S
10k is a bit low for amp & woofer.
if u want to stick to ur budget then, check out the team-bhp market space for HU, Only front speakers amp and sub.
3k for HU
2k for front 2way, 3way or components ( components may not be possible.)
3k for 4chanel amp
and 2 k for sub.
wires and install may be 1-2k more.
EDITED....
Search for the following - since iam not sure outside links are allowed here.
Pioneer MP3/CD Head Unit DEH-P7650MP - 2500 OR
Panasonic RX222(MP3 player with aux and 2 pre out) - 4200
Pioneer TS-G1640R 6-1/2" 2-way car speakers - 1600
Pioneer Subwoofer VCCS TS-W304F 300W RMS - 2500
6 months Old JBL GTO 937 Speakers - 6"x9" - 2300 - if u want rear speaker and not front one. - i prefer front or better both. - front on amp and rear from Hu as fills.
Kenwood 2 Channel Amp KAC 5203 (Reduced Price) - 2000 - for 2 speaker, if u use a active sub woofer so amp connection on it wont be needed.
Xenos - Active Subwoofer - 5500 - with inbuilt amp.
U can play with these options to suit ur budget.
UM
im getting the following for these prices with B&W. Are they right? And will it be a good system? Suggest alternatives if theres something better at that price point.
Panasonic RX222 - 3.8k OR Pioneer 1150- 3.8k(which 1 shud i get?)
JBL GTO 938 6"X9"- 2.8k
Sony Xplod amp - 3k.....
If you wanna do in stages then,
Get used Illusion 6.1 comps for 4.5k
Used Pio HU for may be 3k (not sure)
Later add
Sub - used GZ 3.5k
Amp - The good JBL amp will set you back by 8k
Interconnects - 2k
If you dont want to do in stages & want to finish off in 10k then, just get Pio HU, JBL comps + JBL 6*9.
Pls chk Tbhp market place, you will get lots of used stuff there. Also, its better to avoid Sony for car audio.
