- What is your budget?
- 11000K
- CPU - AMD PHENOM II 555BE
- Motherboard -
- GPU -
- RAM - 2GB DDR2
- PSU - Corsair 650W
- 120GB HDD
EVERYTHING
- MONITOR 19+ inches
- UPS
- KEYBOARD
- NA
- Kolkata
- Open to online purchase if cheaper than local and also reliable.
- If really good deal why not.
- Typing and translation.
- Lots of reading.
- Gaming - na
- Desktop - 1920x1080, not sure though
- NO
- Windows XP/7
