Hi,
I'm planning to buy a 27 inches LED monitor however not sure which one to opt for, I have searched and found following options:
Benq - EW2730 - Panel VA - Response Time 12 ms BTW - 6ms GTG | HDMI x 2 + D-sub + DVI-D + Speakers 3w*2 + headphone jack + audio line in/audio line out
Asus - VK278Q - Panel TN - Response Time BTW- NA - 2 ms GTG | HDMI, DVI-D, D-Sub(VGA), Speakers 3w*2, headphone jack + audio line in
Samsung - S27A550H - Panel TN - Response Time BTW- NA - 2 ms GTG | [font=Arial, sans-serif][background=rgb(255, 255, 255)]HDMI, D-sub[/background][/font]
View Sonic - VX2753mh- Panel TN - Response Time BTW- NA - 1 ms GTG | [font=Arial, sans-serif][background=rgb(255, 255, 255)]HDMI *2 , VGA[/background][/font], Speakers 2w*2, headphone jack + audio line in/audio line out
Benq looks the best among the above in terms of asthetics, really like the metallic finish. I'm stuck between Benq or Asus. Was wondering if there are any other worthy options in 27". Also how good is the IPS panel compared to TN or VA if in case it will will be used mostly while sitting in front, I know IPS provides better viewwing angles, anything else? Better colour reproduction or anything?
Main Usage: Movies n games, also plan to connect to set top box using HDMI for watching TV sometimes.
Ports : HDMI | DVI | VGA
Budget : 20 - 30 K
Resolution : 1080p or more
Budget : 20 - 30 K
