chn
Recruit
Hello,
Even though there are a couple of similar threads, i'm posting this after much consideration as it'd be great to receive some more specific advice
Thank you
Thank you
- What is your budget?
- Upto 70K
- None. Starting from scratch
- None
These are a few things i have in mind
- Intel i7 series processor, if feasible/reasonable enough
- Workstation graphics card, most preferably
- 24" Monitor
- Should have a nice case (compatible for adding components in the future, easy to clean, good air flow etc.)
- Good UPS
- Basic mouse and keyboard
- Can a decent graphic tablet fit in this budget? (eg. Wacom Bamboo)
- This will be the final configuration for quite some time
- Bangalore (SP Road)
- No
- 3D Modeling and rendering (Primary use)
- Image editing (Photoshop, Lightroom etc)
- HD movies
- Strongly considering i7 processors, open to AMD systems if reasonable
- Strongly considering WD hard disks, influenced by backblaze's reliability tests - http://blog.backblaze.com/2014/01/21/what-hard-drive-should-i-buy/
- Are Nvidia quadro cards better than AMD firepro cards?
- Preference towards APC brand UPS
- Action
- Racing
- HD 1080p
- No
- Windows 7/Windows 8
