not so long ago i purchased a Panasonic TZ10.Overall am very happy with the camera but thinking abt purchasing something better.particularly want that bokeh effect.So after some research have almost made up my mind to purchase a sony nex-3 camera with 18-55 mm lens.But i have a few concerns nevertheless.Hopefully someone here can clear those:-
1) firstly sony is an interchangeable lens camera and as per some is a high possibility of dust particles settling on the sensor.now what are the chances of dust particles settling on the sensor even if i don't remove the lens from the camera often.Also is this covered by warranty--i mean if this happens will sony remove those free of charge??
2) Secondly since i don't know a whole lot abt cameras will be mostly using the iauto mode. But from reviews it seems more often than not nex-3 takes overexposed images(sony doesn't allow exposure control in iauto mode).Now can i correct those using software s like lightroom or picasa?? What are the trade offs involved ??
3)Can anyone tell me how good is the macro mode using the supplied 18-55mm lens ??
4)I am used to motorized zoom on the simple P&Z. Will the manual zoom be an issue?
Although c3 is gonna release in india(soon?) if i am not wrong it is not a major improvement over nex3 nd with the price currently touching 19.5k may not be a bad deal at all. Infact many travel zom cameras come close to that price range. What do you people think?
And most importantly how do you make sure you don't end up with a bad kit lens?
Pls reply fast.
Pls reply fast.
