Anyone can you recommend a inkjet printer as per following requirements.
* Primary for school children use
* Multi-function (scan, print, copy)
* with color option
* WIFI (a kind of important - as i don't find enough place to keep the printer near the desktop/laptop)
* 100% home use
* images, text, graph prints.
* photo paper print if possible (Or should i get a separate photo-print ONLY printer)
* Budget apprx under 7000Rs. (may be extended if something worth)
I did like the Epson L210 image print (I did not check the WIFI option though). But its above my budget. Do recommend a decent A.S.S service network in south india (Bangalore, Hyd, Chennai) for the brand.
* with color option
* 100% home use
