It's been 2 weeks since i recieved my pl-50 and i still haven't found the right fit. The sound degradation is so drastic without a good fit that i might consider selling them off if i don't find a solution quick.
So please suggest some replacement tips (silicone or foam) that is compatible with its nozzle size (~3.5mm) and offers good seal, comfort and durability. Price isn't an issue but it should be available on Amazon.
Also please note that i don't prefer modding (cutting/gluing etc).
