blackystrat
Recruit
Hello
This is my first post in this forum. I have seen threads on air conditioning here so I thought of seeking advice from you all regarding my AC problem.
I have a Samsung Crystal+ split AC of 1.5 ton that i have been using since the last year. Of late I have noticed that the AC makes a whooshing sound constantly and it is more prominent when the blower works at the lowest speed.
I also feel that the flow of air from the vent is not uniform in a sense that the air blows fine from the left and right corners of the vent, but the flow is not consistent from the middle part of the vent. Sometimes I can feel the air coming from the middle portion of the vent and sometimes I can't. Maybe that's where my real problem lies.
I also feel that the cooling is not adequate. Previously the room used to get chilled at 25 degrees, but now it doesn't get that cool even at 24
I had called the samsung technicians and they said that it is because of dust accumulationon the filters; but even when I clean the filters, I still get the whooshing sound and inconsistent flow of air.
Please advice of what might have gone wrong with my AC. I think it's either the valve gone faulty or there is a chunk of dust accumulated somewhere which is obstructing the air flow and causing the whooshing sound.
Please advise
Thanks a lot
Please advise
Thanks a lot
