Airconditioning Help
Single phase can easily run a 1.5T unit without breaking a sweat. Along with a couple of other appliances which has a high power draw. I am using a 1.25T unit with a single phase connection.
no domestic appliance comes in 3 phase,
2 tons 2.5 tons - to go any number of sites and check - 220V all of them
3 phase - 440V - your home wiring is NOT 3 phase.
Hi guys finally narrowed it down.
1) Daikin 2 star 1 ton for 33k inclusive of fitting and V guard Stabilizer
2) Bluestar 5 star series 1 ton for also 33k inclusive of fitting and an Everest stabilizer
looking for a quick reply guys heading out to get it today itself..
BTW how are Everest stabilizers compared to V Guard. Dealer mentioned he sells them because they have a 5 Yrs Replacement warranty & V Guard Doesnt.
4
There was news ~ a month ago that Daikin is launching models to take on the Koreans, ~26k.
Re-Look around, you may find it.
