Budget 90k+ Are all parts compatible? Any cheaper/better alternatives?any additions?
CPU -I5 12400f - 12500₹
GPU -Asus rx6650 xt - 24199₹
MOTHER BOARD -MSI pro B660M-A wifi DDR4 Motherboard- 14890₹
SSD - Samsung 990 pro 1 TB M.2 NVME gen4 internal ssd - 10700₹
RAM - Corsair vengeance LPX 16GB DDR4 3600MHZ - 3249₹
POWER SUPPLY -Cooler master MWE 650 bronze v2 Non modular power supply - 5300₹
PC CABINET - Galax rev-06w pc cabinet 4 fans - 5000₹
MONITOR - LG GN800 27" 1440P IPS 144 HZ - 22300₹
After much research, ive devided to go for this build as it meets my requirements and budget. Not looking for any fancy rgb. Please give suggestions.
TOTAL ESTIMATED PRICE - 95000-105000₹
Any reason for considering such an expensive SSD? If you're looking to reduce the cost, then this is the obvious one where you can save around 5k by going for WD SN580.
I will be storing and transferring heavy photos and videos, so I need faster read/writes speeds. What about xpg gammix s70?
Yes, seems like a good alternative. Is it color corrected? I don't understand dci-p3 vs srgb. I'll be editing photos, so I need more or less a color accurate monitor.
From what i have seen these come as default color corrected out of the box. But to be sure i will check and let you know but only next week as i am out. Someone else can also check and update as some other's have also bought the same v3.
U can grab the deal for i5 12400f at Flipkart... currently it is available for 10k around after all offer...and save your money
