AUX cable help
hahahari
Discoverer
Hi guys,
I need an 3.5 male to 3.5 mm male to connect my amp on my portable setup. So I need soemhting really small. Any help? Preferably, I just want to buy it online.
iBasso Ones are pretty good they use High quality Connectors and good custom made wire.
if you can Import , i will recommend one.
IF you are asking about how to make one, SKIP it :)
you wont have a soldering iron for the job
cause it involves soldering, But is quite easy to make.
- Get 3wire microphone cable ( preferably high quality )
- GEt 2 Nutrik 1/8" connectors
- Solder it .
@strategy and benny, I think I am going to make one by myself. I do have a soldering iron. I studied electronics in engineering :)
Thanx for all the help guys, much appreciated :)
