    Sincerely,
    The TechEnclave Team
FS: Home Audio Video Avantree Oasis Long Range Low Latency Bluetooth Transmitter Receiver
saggyN73
Feedback: +3 / =0 / -0
Pune
5 out of 5
  1. Cash
  2. Bank Transfer
Excluded - at actuals
No warranty available in India
No
No longer required
• Product Name: Avantree Oasis Long Range Low Latency Bluetooth Transmitter Receiver
• Expected Price: Rs 6000
• Shipping charges: Excluded - at actuals
• Manufacturer page URL: https://avantree.com/oasis-bluetooth-transmitter-receiver
• Description if any: This device makes any TV, Speakers, Home Theatre, Projector Bluetooth enabled with highest audio quality possible.
It is in 2 in 1 device. It works as receiver; means you can play audio from your mobile/laptop's Bluetooth to your non-Bluetooth speakers/home theatre/sound bar.
Also, it works as Transmitter, means it can send audio from your non-Bluetooth TV/Computer/Or any device which gives audio output and transmit it to your Bluetooth headphones/speakers with highest audio quality possible using aptX codec. You can watch late night TV without disturbing others by connecting your BT headphones to your non-Bluetooth TV.
Now almost all TV manufacturers like Sony, LG, OnePlus, Samsung includes Bluetooth connectivity option in their TVs, however Bluetooth module which is used in these TVs is very basic and can offer only inferior audio quality to your Bluetooth headphones or speakers as they do not support high-definition audio codec such as aptX and aptX LL. This device will let you enjoy TV's audio using these codecs without any compromise in audio quality. More features are as follows:
Long Range Bluetooth Transmitter Receiver
Certified aptX Low Latency, Dual Link, Voice Guide, Pass-Through Function
Bluetooth enable
Extended range
No lip-sync delay
Easy to use
Multi format audio support
Bluetooth enable
Bluetooth-enable virtually any of your audio devices at home. Use the Oasis as a Transmitter to stream audio from your TV, or computer to a set of Bluetooth headphones. Or use the Oasis as a receiver and allow your home stereo or speakers to play streamed music from your cellphone or laptop. Connect the Oasis in between your TV and Sound bar - then use the convenient bypass switch to choose between your sound bar (bypass mode) and streamed Audio (Bluetooth mode) without the need to plug/unplug any wires.
Easy to use
The Oasis supports full-featured voice guidance and status/ codec indicators, making it incredibly easy to set up and use.
Supports digital OPTICAL / AUX / RCA audio output standards making it compatible with 99% of the TVs on the market.
Extended range
Experience the wireless freedom to walk anywhere in the house! Proven range of 295ft in testing with headphones (audition Pro), and 328ft using Oasis as a Transmitter, RC500 as a receiver Pair in open air line-of-sight conditions. Note that operating range can be affected by multiple factors.
No lip-sync delay
Supports the aptX Low Latency codec to virtually eliminate audio-visual lag making the Oasis an ideal choice for watching TV / movies.
Specifications
Audio codec support - aptX-LL, aptX, SBC
Audio Formats - PCM / LPCM (Set your TV audio as PCM/LPCM format)
Bluetooth Profiles - A2DP, AVRCP
Operation Range - Class 1, up to 164 ft / 50m
Input voltage/ current - DC 5V/ 500mA
Power Supply - 5V/500mA-2A rated USB charger or TV USB port
Power Port - USB-A
Product Weight - 0.32 kgs
