JediMaster said:Now need one on WaterCooling ... !
Okay....
1. Get a waterblock from the US
2. Get a nice quiet pump.
3. Get a Maruti 800 radiator (non leaking) from ur local gujri. Get it thotoughly cleaned and test it for leaks at some radiator cleaning shop.
4. Get a container big enough for the reservoir
5. Get 2 metres of 1/2" ID hoses
6. Get some Engine coolant and lots of distilled water. prepare the coolant mixture by adding 4 parts of water to one part of the coolant.
6. Connect just the waterblock, the reservoir and pump and run a leak test. ( run it for 5-6 hours straight to make sure the block isnt leaking)
7. Precisely measure the pipe lenghts, cut them accordingly.
8. Mount the waterblock, connect all parts....dont start the computer yet, run just the pump for about an hour so that all air escapes and no leaks are found.
9. U are all set, go do some serious ocing..hehehe
SunMysore posted 0.85 minutes later:
ooops..forgot the fan part
get a good fan, and design a good housing system for it.
