Budget 0-20k Basic Home PC for 20k (max)
Game24
  1. Q: What is your budget?
    • 20K (maximum)
    None
    None. Entirely new
    • Anythin within my budget
    • Final
    • Mumbai
    • No
    • Normal Home usage
    • Nothing like that
    No games
  11. Q: What is your preferred monitor resolution for gaming and normal usage
    1. 1366*786
    • No
    • Windows 7 32bit
