Budget 21-30k Basic PC Advice for Home under 25k
hari1
stions
  1. What is your budget?
    • 25k Max can extend 1-2k more
  2. What is your existing hardware configuration (component name - component brand and model) 10years Old pc
  3. Which hardware will you be keeping (component name - component brand and model ) Mouse,keyboard,UPS and speakers
    • CPU - core i3 3110 or 3220
    • Asus DVDRW optical drive
    • 500gb seagate baracuda
    • 19 inch HD monitor
    • PSU
    • Motherboard
    • RAM-4GB
    • Any good cheap cabinet
    • Yes, will buy in a week
    • Not upgrading anymore.This is the final
    • Hyderabad
    • Local shop
    • No
    • Browsing
    • Desktop Processing
    • No to transcend
  10. If you will be playing games then which type of games will you be playing? no gaming
    1. Desktop -1280x720 /1600x 900
    • No
    • Windows 7 64 bit
gigabyte B75mD3H mobo
pentium g2010 or i3 3220 (Choose depending on budget)
Corsair value ram 4gb
caviar blue hdd 500gb
Fsp sagaII 400w
Zebronic cabinet
Dell IN02030M
If there are power fluctuations in your area get a basic UPS.
You may also consider an AMD rig with A4 4000 or A8 5600k
Fsp sagaII 400w
Zebronic cabinet
Dell IN02030M
Prices of those components ?
I am not aware of the changes in prices due to rupee value going down.
Call a near by shop and ask for quotes.
I went yesterday to local shop..Checked almost 10 shops..I didn't find fsp saga psu.
I went through some posts here,most are suggesting nzxt gamma cabinet,But i didn't find it either..Seems they are good..
Where do i get these two online.?
Buying cases online will increase the cost due to their weight.
Alternatives are nzxt source 210,Antec Basiq 300w.
Websites:
Primeagbg
Itwares
Itdepot
Deltapage
Smcinternational
