Hi!
I am looking build a basic system for my sister who is studying design as an undergraduate in NID. I plan to give her a system soon.
1. Q: What is your budget?
As low As possible
2. Q: What is your existing hardware configuration?
No system yet just parts lying from my inventory of spares
3. Q: Which hardware will you be keeping?
Keyboard--Benq
Mouse--Gigabyte GM 6800
Speakers--Creative
Cabinet--Gigabyte Luxo M142
Harddrive--WD 500Green
4. Q: Which hardware component are you looking to buy?
CPU+Board+LCD+ram+psu+gpu
5. Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future?
Yes
1. Ahmedabad
2. Open to online purchase
3. Mumbai
7. Q: Would you consider buying a second hand hardware from the TE market?
1. Yes if there's anything with warranty
8. Q: What is your intended use for this PC/hardware?
1. NO GAMING
2. Browsing
3. Desktop Processing
4. Photoshop+various animation software+designing/content creation software
5. Download rig, 24x7 operation
6. Watching HD movies-1080P
9. Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike?
NO
NO GAMING
11. Q: What is your preferred monitor resolution for normal usage?
Anything will do
No
Windows 7 64 bit
I would prefer this system to be a low power consuming system. I have 4gb of OCZ ddr3 1600 Platinum ram, 8800GT and Corsair VX 450 but I guess that would be an overkill for what I need and it would be extremely power hungry.
As low As possible
Keyboard--Benq
Speakers--Creative
Yes
1. Ahmedabad
3. Mumbai
1. NO GAMING
2. Browsing
NO
NO GAMING
Anything will do
No
Windows 7 64 bit
