Battery compatiblity with inverter ? which one you're using?
max_demon
@maxdemon
Galvanizer
Hey guys I'm planning to get a good sine wave inverter possibly about 2kVA
Nixown - Wings of Power | Home
are there any other good true sine wave inverter to look for :-?
my budget is about 35k for inverter with battery. I intend to use 3 fans, 2 cfl (85W), 1 desktop (650W psu) and 2 laptops and a refrigerator while there is power cut.
power cuts is uncertain.. mostly planning to use as UPS.. most of the times power is off for about 15-30 mins.. but in some days its upwards of 8 hours..
so it should be enough to power.
and are all the battery tubular or flatbed.. compatible with all the inverter? if not. then which one is best to buy for that nixown inverter.?
