battery for inverter
deepak3775
Inactive
Contributor
i've got a 1400w su-kam inverter.i need to change its 2 batterirs.
can anyone tell me the best vfm batteries around and rates.should i get regular(water topups reqd freq) or the ones which dont need water to be filled.
i'm from kanpur(u.p.) and we hav 12-14 hrs scheduled power cuts daily.so pls keep that in mind while advising me.
i'll be using it to power 1fan+1cfl(12hrs) and a 200watt water cooler(2-3 hrs).daily.
Hmm go for Exide would say but they will set you back by about 20 grands. Model: FEI0-IN1500PLUS
Let us know how it goes through.
~LT
~LT
is that 20k per batt or for both.also what type of battery is it(water)
Nope its together (10+10). Nope its sealed tubular once:
FEI0-IN1500PLUS
Exide Invertor range of batteries are specially designed for Inverters, with very low maintenance, high reliability and extended cycle life, instant state of charge indication, clean top with no surface leakage and fumes. Maintenance Free, Factory Charged ready for Fitment, 2-Year Pro-rata Warranty.
Store:&nbsp Inverter
~LT
i've been surfing teambhp forum and most of the people there hav bad experiences of exide batteries.
can anyone tell me the rate for amaron or tatagreen maintainence-free batteries for inverters .also pls mention the warranty period
Dude,
Be carefull about your conclusion. Team BHP is about CARS and battery for car is way different then that for inverter. Get your facts clear.
And an eye opener:
Amaron Battery Complaints
Man Amaron site is sure a putoff it keeps showing a racing car's rear!
~LT
Exide all the way. I've been abusing my batteries for quite some years now still no decrease in performance or whatever. :)
linuxtechie said:
Dude,
And an eye opener:
~LT
hi,
i've checked the site and there r 2 complaints of amaron but also 6 complaints of exide.how r the tatagreen batteries?
can u post rates for diff batts
deepak3775 said:
hi,
Right... but u need to understand that those batteries need maintenance. Hell every battery needs maintenance (Even Inverter battery). I have Amaron in my car and wont say am exceptionally pleased with the same. Get it? Also search on Amaron inverter battery yield nothing, so guess its not common out there, so if there are issues, u r stuck, get it?
Same with tata green, search with inverter doesn't yield anything from tata themselves, so how much confidence would u expect in those brands?
~LT
I'm also going to buy a battery for an inverter. We have power cuts upto 8 hrs where my mom lives. SO i need a battery which can provide this long power backup. Whats the AH i should be looking at ?
Will a 150Ah Exide tubular suffice or shall i go in for a 165Ah normal Exide. I'm saying exide because it has been used by many people and a bit more or less, the have been reliable.
BTW i have a local inverter which i bought from delhi, 850VA@Rs 3200 :tongue: but it worked gr8 for the few days my bro used it.
Also my usage for the three months i'll be there is approx 250 watt so the battery should helpin lasting about 6 hrs at 200-250 watts. :)
