Laptops Battery Problem Toshiba Satellite L640
thatsashok
Inactive
Explorer
I have a 3 month old Toshiba Satellite L640 X314A laptop
the laptop battery condition in Health Monitor is showing Fair (not GOOD) and whenever my battery reaches low charge it hibernates without saying a message popup
"Please find another power source"
which i find on all of my friends laptop.
And the battery is holding charge only for one and half hour..:no::no: So i am thinking of battery replacement ASAP. But my doubt is about that popup in windows
What do you people think about Windows 7 not showing that popup???
Is there any setting to enable it or is it due to Battery problem???
does the windows 7 OS came with the lap or not.Check Toshiba website for any updates/patches on the same, try an clean resore OS option under Toshiba>tools option.and check the same again, dont worry as the warranty is valid for 1 yr .If the same problem persists contact HCL service shop in calicut with ur lap/adaptor/set for RMA claim.
Please feel to contact me for any further help on the same.
Windows 7 came with the Laptop. And Toshiba isn't working with HCL anymore I guess. They moved out and started onsite programs and only servicing via dealers.
I did not get what you meant by..
Did you mean Toshiba Assist for Toshiba tools???
Will reach out to you for help in case i need it . Thanks man
plz contact
Name Address Phone Mobile Fax Email ID
Compumobiles 2/2368, A-G, Near Gandhi Asram, Civil Station PO, Malaparamba, Calicut - 673 020 0495-3204244/2375850
a div of Nortech Cochin, Doing Toshiba ASP in CALICUT
amd999 said:
plz contact
will be going for replacement within 15 days
right now busy with my mini project and exams..
thanks for the info man..
