Best Detergent/Washing powder for Top Loading Washing Machine
andy1978
Contributor
I have an LG Top Loading Washing machine which I have been using for the past 2 years. I have used couple of detergents both powder and liquid. Though liquid looks better still I'm unable to get satisfactory results from any of these. Can someone suggest a good brand of Detergent to me.
I have used the following:
1. Genteel(Liquid)
2. Amway(Liquid)
3. Surf Excel for Washing machines
Surf Excel is good and if stains are tough then use Vanish... :D
There is separate detergent tray in washing machine and during intake of water machine passes little H2O in detergent chamber turning it into liquid solution and then it enters spinning drum...
U could also use fabric conditioner like this : Comfort | Home care brands | Unilever ... there is different tray for using fabric conditioner in washing machine...
Hope this helps ...
Use Surf (normal/machine walla, your choice, we use the former). Use Comfort while rinsing/spinning.
IMO, Amway is useless.
