Ssreek
My senior professor wants to record his lectures. Need to record both in-class videos and also record some videos at home.
These classes will be anywhere from 1 to 3 hours. He should be able to use the device both for offline recording and sometimes live classes on zoom.
So there are a few methods suggested for this:
Looking for suggestions if there is a better way.
- One way is to use a DSLR with a 50mm lens. The only issue is battery won't last more than 40 mins, so either we need to take more breaks and keep replacing the battery or get a dummy battery pack with ac connection (but these are unreliable and sometimes may ruin the camera).
- Another is to get a decent to best webcam. This way, no need for battery worries, and it can be connected to a laptop and used for hours. Only issue is such webcams cost a minimum of 10K and we are not sure if it is worth it considering the video quality we get for that price.
- Tried using phone to record, but phone gets heated after a while due to continuous use of video recording, and also getting it connected to a laptop with stable connection is a software mess.
