Brainwavz M2 In-Ear Earphones
Introducing the Brainwavz M2, the third Brainwavz to be released by us. The M2 is quite different from the Alpha and the Beta models, the M2 provides a more mature, detailed and refined sound, but above all the sound signature is fun and exciting, two words that will quickly be synonymous with the Brainwavz M2.
The M2 also brings a new level of quality and detail to workmanship, the new cabling is of higher quality and helps to preserve the sound quality from your source gear and the earphones are constructed in a metallic body. The M2 is designed to sound good with any genre of music, be it from pop to hip hop to country.
The M2 will also be covered in a new premium warranty, should the M2 stop working for any reason (other than damages caused by a user) within the first 12 months after it was purchased, it will be replaced for a new unit!
Reviews:
- Review by ClieOS from Head-Fi - read review
"When I first joined HF, sound quality like that of the M2 would have been well over $150, and yet today it is priced far under $100. It is incredible that newer IEM in the lower price range continue to surprise us with better and better sound."
- Review by PolloLoco - read review
"The CX500's from a reputable source are about the same price as the M2's - and the M2's best them in almost every category. Build quality, sound stage, bass, mids are all owned by the M2."
- Review by dragon2knight - read review
"They caught me a bit off guard with the way they handled certain types of music, especially Jazz and Opera, and I would highly recommend them to anyone looking for a high quality and well made pair of In Ear Headphones"
Specifications:
Channel Balance |<= 2dB
Driver Diameter |10.7mm
Rated Input Power |10mW
Sensitivity |115dB @ 1mW
Distortion |<= 0.3% @ 94dB
Maximum Input Power |40mW
Impedance |20Ω Closed Dynamic
Plug |3.5mm, 45 degree, gold-plated
Frequency Response |20~20,000Hz
Cord |1.3 meters Y cord (CU/Ag) PUR
Warranty |1 Year
Included Accessories:
- 3 sets of silicone tips (S/M/L).
- 3 sets of foam tips (S/M/L).
- A pair of gliders for over the ear use.
- Hard case to carry the M2 around.
- Shirt Clip.
FiiO E3 Portable Headphone Amplifier
The E3 is a headphone amplifier, it is designed to improve the sound quality of MP3 MP4 Players, Computers or Mobile Phones when using earphones or headphones. It saves your player battery and lengthens the play time when playing music.
It’s not about Volume but Quality. A great pair of headphones can change you're listening experience--but only if they are driven well and properly powered. Put an E3 Headphone Amplifier between your music source and your favourite pair of headphones or earphones for an awesome personal listening experience right between your ears.
Features :
- Designed for high impendence and low sensitivity headphones, with bass boost function
- Small and easy to carry and use in the outdoors
- Increase your music player's play time
- Uses only one AAA battery, for 20 hours playtime
Specifications :
Signal to Noise Ratio |>= 90 dB (A Weight)
Distortion |< 0.05% (10 mW)
Frequency Response |10 Hz - 40 kHz
Suitable Headphone Impedance |16 ohms - 300 ohms
Weight |11 grams (without battery)
Power Supply |1 AAA Battery
Dimensions |55 mm x 23 mm x 14.5 mm
Mediahome.in Premium Gold Plated 1.5m 3.5mm Male to Male Cable
- 3.5mm male to male
- 24k gold plated connectors resist corrosion and ensure a perfect
- Fully Shielded - Pure Crystal Oxygen Free Copper Cable
- Easy to install
- Durable
- Robust
- Reliable
- Compact in size
- 1.5 Meters
Note: Picture is for Illustration purposes only
Cost - Rs. 2790 + Shipping
- Mediahome Digital is the channel partner of PristineNote in North India for Brainwavz Products.
- Warranty can be claimed by going to the Delhi or Mumbai Office or sending it via Courier.
- Earphones are in Ready Stock.
To Order Visit :
Brainwavz M2 In-Ear Earphones + FiiO E3 Amplifier + Premium Gold Plated 3.5mm Cable
