no
Monitor- I already have this from my friend(Samsung20"LED).
CPU - Intel Core i5 3550/3450
Motherboard - any compatible motherboard
Ram: 4GB
hard Disk: 1TB Segate / WD
SMPS: pelase suggest one
cabinet: please suggest better one with proper cooling
RAM - 8Gb
GPU: Nvidia GT520M/ ATI
Mysore
open to online purchase ( please refer which stores I get with less price)
NO
Photoshop editing
Browsing
Desktop Processing
Watching movies
Medium level Gaming
No
No
None
Yes
Windows 7 64 bit
Linux - Mandriva
Please suggest best stores in Mysore or best online stores with less price... Thanks in advance:yes:
bkishore Go with tihs-
Intel Core i3 3220-6.5k
Gigabyte GA-B75M-D3H-4.5k
Corsair Value Ram 4GBx1-1k
Segate 1TB 7200RPM-4.3k
Corsair CX V2430W-2.4k
CM Elite 311-2.2k
Your budget is too tight to get an overclocking rig,You'd have to settle with i3 3220 which is good enough for your requirement.
Hope this helps.
