-=Unreal=-
which printer to go for under 3k, cannon or hp?? which one is cheap/easier to refill??
pls...reply....
pls...reply....
How much pages can be printed in one such filling for medium quality prints??Emil said:Look for HP D1460 or D1560. These are discontinued and not easy to get but if you do get them they should be under 2K. They use HP21/HP22 cartridges which are a refiller's dream. Makes them very cheap to run.
Canon printers use PG40/CL41 cartridges which have high capacity but have not been as successful in the refilling department. Speaking from personal experience.
Whats the price for new catridges?sato1986 said:Im using HP Deskjet F2235 (Printer-Scanner-Copier).
Love it for features, Scan quality, Print quality, refillable cartridges
-=Unreal=- said:How much pages can be printed in one such filling for medium quality prints??
-=Unreal=- said:Whats the price for new catridges?
how many pages can be printed with new cartridge in medium quality setting?
-=Unreal=- said:My requirement is 100 pages(blk&white) per month, which printer suits me best in long run?, Is it better to go for laser printer costing 6k? one of my friend told me that laser print can print 2000pages in a single re-fill is it true?
-=Unreal=- said:^ ok thnx for replying, also pls suggest me a entry level laser printer which will be cheaper to run with low cost cartridges, becoz my printing volume may go up, and i dont need color printing.
First of all, thanks Eddy for branching the thread.-=Unreal=- said:^i dnt think so, OP with a single post is not going to come back he is long gone.
i dnt want to create another printer thread...so if u can pls suggest a entry level laser printer.
Yes those cartridges are fantastic for low running cost but that is all part of strategy. HP has already squeezed you when you buy those printers so they don't need to suck your blood for the cartridges. At the lower end, they sort of give away their printers and buy your soul.Crazy_Eddy said:[mod]Posts moved to new thread[/mod]
The new kings of the hill among HP's inkjet cartridges are the HP 703 series cartridges : HP 703 Deskjet Ink Cartridges summary - HP products
Page yield as estimated by HP is 600 pages for the black / 250 pages for the colour.
Each cost Rs. 415. Thats about ~0.7paise/page for black and white prints.
At this time, the HP Deskjet D730 and the K109 are the only two printers that use this cartridge (HP F735 and K209 are the equivalent all-in-one models).
The D730 has supposedly been phased out and replaced by the K109.
However availability of either printer is a bit scarce out here in Chennai, not sure why.
Was pretty much in the same boat as you - wondering whether to go for an inkjet with low running costs or an entry level laser printer. Emil summed it up well in what should be your deciding factor. I needed the occasional colour print and won't be printing that much, so settling for the inkjet.
I might also add that laser printers are a bit bulky/heavy, so factor that in as well.
Crazy_Eddy said:^ Yep exactly!
My apologies, I thought I mentioned the cost of the K109 earlier :ashamed:. Anyway, its ~4.1k, which is a bit expensive to start with.
The cheaper cartridges can offset the cost - but it all depends on the number of pages you expect to print per month.
As an eg:-
TCO for 100 pages / month after 2 yrs :-
HP D1560 - Rs. 5750/-
HP K109 - Rs. 5395/-
TCO with 200 pages / month after 2 yrs :-
HP D1560 - Rs. 9950/-
HP K109 - Rs. 7055/-
So you need to print atleast 100 pages a month, to expect the K109 to work out cheaper after 2 yrs. If you print more/use it longer, the Total Cost of Ownership is only going to drop further and further (significantly as you can see above).
One more thing, all the comparisons are done with genuine cartridge prices alone. Refilling will work out cheaper, but since it will equally affect both, I did not bother.
mithun said:Just FYI,
My HP21B depleted itself at just around 100 pages of plain A4 text. The good thing is that a 30 bucks refilling kit and 5 mins of effort got it up n running againhyeah:
-=Unreal=- said:I think Epson Stylus TX111 all in one is cheapest to run with original cartridge costing Rs 250 = 180pages.
Any other options?
Any other options?
Emil said:That shouldn't happen. The HP21B capacity is the same as the HP21.
True. There are 3 colour cartridges plus one black, each costing 250/- which is an advantage because you actually need to replace only one colour at a time. That is the T091 series. There is also the T073 series cartridegs that are about 400/- each and will fit in the same printer. They have higher capacity.
All that looks very good with paper calculations.
In real life, my personal experience with Epson has never been good. I first opted for Epson because their heads used peizo transducers and technically, I feel peizo technology should be more reliable than thermal technology. But the actual results were far different.
That's when I gave up Epson probably 6 to 7 years back. I have no reason to believe there is any improvement now.
I used to be against HP in those days because HP was known for paper jams. This is because their paper path has sharp bends so that paper can enter and exit from the front for convenience. Although HP has still retained that complex path, they have succeeded in making paper jams a thing of the past.
Canon has consistently been good and reliable but my experience with their current cartridges PG40 and CL41 is bad.
I got my HP F2120 in end March and it cost me around Rs 2900/- home delivery.cyneuron said:epson stylus tx111 seems to be the best product in this segment (low usage of prints; but need AIO).....
costing just 3.2 k (ordered from authorized dealer for a home delivery) ....u get AIO (printer, scanner & copier)...
cartridge are also reasonably prices.....and what more...2 year warranty....
i think u can't get better than this in such a price.....
sounds reasonable but see more of my comments belowcyneuron said:that seems a reasonable reply seeing your experience (but also it was 6-7 year back )...but i mean how can epson be so much bad in comparison to any other company be it HP or anyone else ?
I have not come across anyone who has been happy with Epson reliability. For a home user, the performance may not be an issue as you rightly point out but reliability is. The printer will inherently die out long before the scanner does. Then you are left with a rather large scanner (an AIO with a dead printer) which you are reluctant to throw away and you go out and buy a printer only to complement your elephantine scanner.cyneuron said:the review of this product seems really favorable (except for slow speed of printing, but i guess a home user shouldn't be complaining about it).....
and nothing seems to able to beat the pros i mentioned above....
