10-15K Budget phone with automatic call recording with no sound (beep or message saying its recorded call)
devid
Beginner
1. Budget?
A: INR 10k-15k
2. Preferred display size, type and resolution?
A: Any
3. Preferred operating system? (Android (with version), iOS, etc).
A: Any but preferably get updates for next few years.
4. Preferred connectivity options? (4G, 3G, 2G etc).
A: 5g, low signal strength in my area so phone with good connectivity would be preferable.
5. Do you have any brand preference or dislike? Please name them.
A: No preference. Should have good service network
6. What is your intended use for this phone (internet, camera, multimedia, mails etc.)?
A: Mostly for calls, youtube, WhatsApp, browsing.
7. Single SIM/ Dual SIM?
A: Dual Sim
8. New or Used? Online or Offline?
A: New, online offline any.
9. Any other requirements?
A: Automatic call recording should be there and there must be no beep or recording message, no heating issues and good battery life is preferred.
worried about budget samsung phones slowing down as time goes on, phone should last alteast 4 years, is samsung still fine?
pick one with long yrs of OS updates if you are SBI/YONO user,
and turning OFF animations help, yes it is bound to get slower with exynos,
bigger size and bigger cooling/vapour chamber look for those.
Bro just use third party calling app on your desired phone
Phone isn't for me, it's for someone who's not that good with phones. Do give out some recommendations, I'll check them out for user-friendliness. Some of the apps I've tried before use microphone to record and they audio ends up being very low and can't make out the conversation.
Take you pick,
You can enable Vivo's/iQOO's own dialer.
Redmi/Poco comes with MIUI dialer
Oppo/Realme you can install ODialer
Samsung doesn't announce.
Big battery - T4X/Z10X
Long OS support - M35
Raw performance - P3
share the recommendations
Fossify dailer and contacts
Completely safe and very light
Give it a try you won't regret
