Budget 41-50k Build a PC for Game Design and Development. (Unity, Unreal Engine, Be lender, and other rendering softwares)
Sripad
Recruit
I am (want to be ;p) a passionate game design/developer. I am still learning (want to learn ;p), I don't have a PC right now thinking of building one. My main purpose is for game design/dev and rendering/testing. My second purpose would be to play decent games.
I don't have a high budget, but hoping I could squeeze a decent build here. Also I'd like the build to be future proof so that I can save up and upgrade.
I can go more or less ~60 - 65k.
Ryzen 5 - 3400G - 13500
B450M PRO-VDH MAX - 7500
Ram - Corsair 16gb ddr4 3000mhz - 5000
ssd - BLUE SN550 nvme - 4000
hdd - 2tb seagate barracuda - 4500
Power supply - Antect Atom b550 - 3200
Cabinet - any rgb cabinet of choice - 3000
Keyboard and mouse - any rgb keyboard and mouse combo - 2000
Graphics card - colorful 1650 super - 13000
Monitor any best model of choice and avl 24 - 9000
Speakers - any best 201 of choice - 3000
ups - 1kva of choice - 4500
above comes 70,000+ . rip of to a smaller one( 24 to 22 monitor, basic keyboard and mouse, 240 gb 2.5 ssd for 2500 sub, 8gb only ram for 3000)- of any part if ur budget is strict.
Curious as to why you'd recommend a G processor + a discrete GPU?
This is not a reputed PSU AFAIK,
In anycase video card fails can use onboard video.
B550 is bronze rated from Antec sub brand im already used with an pc not plain white so i recommend it . or buy Antec NeoEco 650M 80 Plus Bronze semi modular 4700 at amazon.
This will cost about 70k
i5 10400F
B460 Pro VDH Wifi
2 x 8GB DDR4 2666mhz or higher (any popular brand will do)
CX450 or NE450/550w or MWE 450 Bronze v2 (try the first one, if it's not available then the next. MWE is the last option here)
GTX 1650S
SilverStone FARA R1
WD Blue 1TB 7200rpm
Kingston A2000 250GB
Logitech KB/Mouse
Benq GW2480 / LG 24MP59G
But for rendering softwares should the processor have high core count? 4 cores or 6 cores sufficient?
(Monitoring, mouse and keyboard not required already have them)
Intel processor, amd board?
Sorry for the typo. Thanks for pointing out.
Yeah, high core helps to do things faster.
If you don't need monitor, then it will comfortably fit in your budget.
