Phenomenal
Special Note : I am a computer engineering student.Assembling for the first time.
Doing this for better understanding and practical knowledge.
Plan to make awesome use of this for years to come so need it to be FUTURE-PROOF!
Any idea/advice/suggestion you give is really appreciated and I want to thank you for the same.
Please ...
Other Questions I have...
1) For PSU,how can I decide the wattage rating?
2) For RAM should i go for 1600 MHz since it will be faster?
3) What are the most important features of a Mobo like which slots/specs it MUST have?
4) How much difference in the clock frequency is actually significant?For eg,what would be the difference of performance for file conversion is seconds for processors with a diff of 300MHz with same components.
5) I want the PC to start in less than 30-40 seconds in the beginning (less apps),for this which component would matter the most?
If there's anything else I should add,please mention that as well.
THANKS A LOT!!! :lol:
- Q: What is your budget?
- 40K + 5K fluctuations and slight changes (if its REALLY worth it!)
- Q: What is your existing hardware configuration (component name - component brand and model)
- HDD - Seagate SATA 500GB 5400RPM
- Monitor - Samsung SyncMaster 510n
- Q: Which hardware will you be keeping (component name - component brand and model)
- Monitor - Samsung SyncMaster 510n (Can change if recommend by you)
- Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
- CPU - Intel i5-3570K (Since it has HD4000,I won't buy a GFX card)
- Motherboard - any compatible motherboard (USB 3.0 ports a must)
- PSU
- RAM - Corsair Vengeance 2GB x 2(1600MHz ?? )
- Cabinet
- Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
- Will upgrade OS to Widows 8 Later
- GFX card if required.
- Q: Where will you buy this hardware? (Online/City/TE Dealer)
- Mumbai (Lammy road or a local dealer)
- Open to online purchase via Flipkart
- Q: Would you consider buying a second hand hardware from the TE market
- NO
- Q: What is your intended use for this PC/hardware
- Browsing (20 tabs in 3 browsers)
- Download rig, 24x7 operation
- Ebook reading,HD Videos
- Adobe Photoshop,JAVA,HTML
- Watching HD movies+tv shows.
- Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
a.For PSU - I heard that most brands pushed by local dealers are bad.Good ones are Corsair,Seasonic.
- Q: If you will be playing games then which type of games will you be playing?
- Caesar 3
- CounterStrike GO
- GTA IV
- Q: What is your preferred monitor resolution for gaming and normal usage
Please suggest a monitor but this will be outside of the 40k.
Mainly for HD movies and browsing (reading stuff online)
Gaming - 1280x728
Desktop - 1440x900 - Q: Are you looking to overclock?
- Yes if required for overall performance and not just for gaming later.
- Q: Which operating system do you intend to use with this configuration?
- Windows 7 64 bit
- Ubuntu
- Windows 8 later
Please ...
- suggest the latest processors which work great ie. that are tested since it needs to be future-proof,
- if it costs more and if its worth it for my use,please mention that as well.
- if you are suggesting some variation,please mention the technical reason.
- Your honest opinion,it's HIGHLY VALUED!
