21-30k Built my PC around 9-10 years ago, Need help fine tuning my build with exact components
Teleyks
Inactive
Beginner
I built my PC around 9-10 years ago and I am back to building a pc which in which i can game competitively. Please help me tune my build with exact components. Thank you
Questions
  1. What is your budget?
    • 20k to 30K
    • CPU - Intel i5 4670 (used)
    • Motherboard - Gigabyte GA d3h h97 (used)
    • GPU - RX 5704gb (used)
    • RAM - 4GB x 2 DDR3 (used)
    • Cabinet - Cooler Master N200
    • PSU - Corsair VS500 watt
    • 1080p IPS Monitor
    • Mouse and Keyboard
    • GPU - RX 5704gb (used) will be upgrading to GPU - RX 6600/6600XT
    • Cabinet - Cooler Master 200 ( need advice if i can keep this)
    • PSU - Corsair VS500 watt ( this is quite badly rated in the tier list wasnt aware when i first bought it, but still in consideration)
    • Open to suggestions on all parts
    • CPU - Ryzen 5600 (used)
    • Motherboard - Any B450/B550 (new/used)
    • RAM - 8GB x 2 DDR4 (new/used)
    • SSD - 1 TB (new/used)
    • CPU - Ryzen 6650XT (used)
    • 1440p (if possible)
    • Pune
    • Open to online purchase
    • No
    • Gaming
    • General usage
    • Competitive FPS - CSGO & Valorant
    • Single player games like - Starfield, EldenRing , Rdr2
    • 1920 x 1080
    • No
    • Windows 10
I've created a build : https://pcpricetracker.in/b/s/b3fafc39-7039-498d-b37e-cd5f9035fda8
Extremely confused with the mobo pick : whether it should be a 450, 520 or 550m
Also confused with PSU's and the cabinet.
Any help would be greatly appreciated!
Questions
    • 20k to 30K
    • 1080p IPS Monitor
    • Pune
    • No
    • Gaming
    • General usage
    • 1920 x 1080
    • No
    • Windows 10
B550m is good and it supports pcie 4.0
Adata Pylon 650w bronze
Case is a personal preference get one which has a good airflow
Also don't forget an air cooler
Reactions: Teleyks
Hi so this is the current build i am getting :
  • CPU - Ryzen 5 5600x for 13k(new from flipkart sale)
  • Motherboard - MSI tomahawk max B450 (used for Rs5.5k with 3 months warranty)
  • GPU - RX 5704gb (already had will upgrade later in the year to rx6750 or rx6700)
  • RAM - 8GB x 2 DDR4 corsair vengeance lpx new for 3.5k (not bought waiting for amazon sale)
  • SSD - 500gb Samsung 970 evo plus 3k (not bought waiting for amazon sale)
  • Cabinet - Corsair 4000D or Lian Li 216(6.5 and 8.5k respectively) (not bought confused and waiting for amazon sale)
  • PSU - Corsair Mwe 850 watt for 5.5k (used with 3 years warranty)
    Total : 36k-38k
Could you please provide me feedback if this build is good, if i overspent or underspent on parts I know went overbudget to a 40k build but I am getting 7k for my previous pc, so that helps offset it a bit. Thank you
Reactions: Kilahswami101
    Total : 36k-38k
Looks good
Reactions: Teleyks
Pylon is a low tier PSU. Other PSUs like Cooler Master MWE Bronze or Deepcool PM Gold series are much better while being in the same price range.
Buy used, everything.....ssd are cheaper right now so u can get them new....rest u can find used cheaper easily.....olx or facebook.....if u want i can share u some whatsapp group links for buying used stuff
Reactions: santhoshr
Config selected looks good. A few suggestion basis my experience
- Upgrade to rx6700/6650xt from rx570 if buying new. Price difference between RX6600 and 6700 is marginal. If possible aim for 10GB or higher VRAM version
- PSU is a criticial component . Ideally should look at Tier B or C PSU. While it might be costlier, it would also outlast most of other PC compnents . If you plan to upgrade to Rx6600XT , 850W PSU will be overkill. 650W should be more than sufficient with enough headroom for any occasional spikes.
- Check RAM compatibility with the motherboard that you plan to install upon. Many unlisted memory modules may not work at all or have limited functionality. In my case 2x8GB Kingston 3200Mhz worked fine with a Gigabyte B450 motherboard in XMP mode while Gskill didnot.
