PC Peripherals Cabinet
ReVo_007
#techie
Galvanizer
Hello guys I am looking for a cabinet in the range of 6k~ . Short listed the Lian Li Dragon Lord K62 and the HAF 912adv . Which one would you suggest ? and you can suggest other model too provided they are in budget . Build quality and airflow is important more than USB 3 shit :P.
The NZXT Tempest EVO best sub-6000/- cabinet, biger, better, badder than both the Cooler Master HAF 912 Advanced and not sure of the Lian-Li Dragon Lord K62.
NZXT Tempest EVO Review - Page 1/6 | techPowerUp.
It has the best air-flow design and the six pre-bundled fans seal the deal for me. I unfortunately had bought the Cooler Master Scout.
Buy NZXT Tempest EVO ~ 5.7k Eyes Closed
Pros: It has great airflow and comes with 6 fans... Its a good looking case too... has good space to take in huge cards...
Cons: Doesn't have sideways HDD bays like NZXT Gamma... So if you have a GPU installed in your system you would have to remove it everytime when you would like to remove your HDDs... Not a big deal if you dont remove or add HDDs more often... :)
MD computers had plans to stock nzxt cabinet...
but don't know if they have actually went ahead n have them in stock.
you could check that out once,just in case!
The HAF 912 advanced is a pretty good model too (if you like its looks). You get options to orient the HDD drive cage parallel/perpendicular to the case and it comes with 2x200mm and 1x120mm fans.. If you can bargain and get it for 5.5k it's a great deal.
well MD i have checked demonic .. pradip ji said he can bring it on order still not in stock . K62 they dont deal in and HAF 912adv I had made them open up a new one just so that i could see it :P . Build quality was not as good as K62 though . Rest Space inside seemed Okish.
