can we filter those sponsored products while searching for specific product? it's very annoying.
thanks, is it good to remove adblock plus now or let both extension run together?
Don't use ABP. https://www.theverge.com/2016/9/13/12890050/adblock-plus-now-sells-adsthanks, is it good to remove adblock plus now or let both extension run together?
AdblockPlus used to be good many years back... for the past 4-5 years most of its users have moved to uBlockOrigin.thanks, is it good to remove adblock plus now or let both extension run together?
I won't say 'most' users. ABP is installed by people who don't know much about the whole situation. And people just simply search ad block and this is the first thing get which is then installed. uBlock Origin is not the top result. Any ABP users just stick with it since they don't know about any better tool. Poor souls.AdblockPlus used to be good many years back... for the past 4-5 years most of its users have moved to uBlockOrigin.
