Laptops Chandigarh/Mohali:-Suggest a Place for Laptop Repair(LCD/Inverter)
tanvirgill
Contributor
I need to get the LCD/Inverter repaired, Would be of great help, If members from Chandigarh or Mohali can recommend a place which is reliable, efficient and won't rip off by over charging.Need to fix it ASAP:@
You can ask for a quote at Kudos info services:
S.C.O. 262, 2nd Floor, Sector 32-D, Chandigarh, 160031
0172 3913544
near the theatre, corner shop.
They deal in chip-level repair, and i guess they are pretty renowned. No personal experience though.
They have a site too: http://kudosinfoservices.com/
^yea but dont forget to tell Amarbir ji that your a TE member :)
Lynx-The Computer Superstore
SCF 4 ,Ground Floor ,Sector 10 ,Chandigarh
Union Territorry ,India .Pin / ZIP Code : 160011
Phone :0172-5087643,5005067 ,Mobile :098150-00133
Thanks for the info guys, Will it make a difference if I Tell LYNZ guys that I am a TE member.
Awaiting some more options.....
cheers!
^ yes it'll make difference if you tell Amarbir that you are a TE member..
His Price Quotes will be better :D
Inverter is faulty.Went to both the places, but replacement(Inverter with matching FRU) wasn't available.
Does the Lenovo service center sells replacement parts?If not from where can I source it. If I buy online it takes 10 days min,to source the part.
