Hi,
I connected my PC and my laptop to transfer files using a crosswire.But the transfer rate is too less.Both the PCs r using windows xp.Can any one help me pls.
Go to Control Panel -> Network Connection -> Select your Lan Connection
Right Click and Select Properties
In the upper right corner select Configure
Then Select Advanced Tab
After that select Link speed and change it to 100 Full Mode from the drop down menu.
If you are using vista the steps would be the same except the last one (they have added a lot of options and link is one of them, change the value from drop down menu from there )
